Looking at the logs, the delay is happening from the time my app tells the Hue group to go on until it finally does go on:
Device |
Time |
Log |
Lutron Telnet dev:1005 |
2018-11-05 05:00:21.372 pm |
info rcvd: DEVICE,4,4,3 |
2018-11-05 05:00:21.499 pm |
info rcvd: DEVICE,4,4,4 |
Bathroom Pico dev:1008 |
2018-11-05 05:00:21.551 pm |
info Master Bathroom Pico Switch button 5 was pushed |
Pico Controller app:1418 |
2018-11-05 05:00:23.322 pm |
debug button 5 pushed |
Hue Group dev:1147 |
2018-11-05 05:00:23.423 pm |
info Group Master Bath was turned off |
2018-11-05 05:00:30.280 pm |
info rcvd: DEVICE,4,2,3 |
2018-11-05 05:00:33.013 pm |
info rcvd: DEVICE,4,2,4 |
2018-11-05 05:00:33.396 pm |
info Master Bathroom Pico Switch button 1 was pushed |
2018-11-05 05:00:33.702 pm |
debug button 1 pushed |
2018-11-05 05:00:33.743 pm |
debug pressNum is 0, On |
2018-11-05 05:00:41.526 pm |
info Group Master Bath was turned on |
Here is my app code in case that might be doing something incorrectly (though it was working up until about a week ago):
* Pico color temp bulb controller instance
* Button 1 presses:
* 1: turn bulb(s) on (can have the bulb programmed to set color temp depending on time of day, when it is turned on)
* 2: set bulb(s) to Nightlight
* 3: set bulb(s) to Relax
* 4: set bulb(s) to Read
* 5: set bulb(s) to Concentrate
* 6: set bulb(s) to Energize
* 7: back to Nightlight, etc
definition(name: "Pico Color Temp Bulb Controller Instance",
namespace: "hubitat",
author: "dagrider",
description: "Cycle through bulb color temps with button 1, off with button 5, dim with buttons 2 and 4 (instance)",
category: "Green Living",
parent: "hubitat:Pico Color Temp Bulb Controller",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Meta/temp_thermo-switch.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Meta/temp_thermo-switch@2x.png")
preferences {
section {
input "thePico", "capability.pushableButton", title: "Choose Pico Remote"
input "theBulb", "capability.colorTemperature", title: "Choose bulb/group to control"
def installed() {
log.debug "Installed with settings: ${settings}"
initialize()
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
initialize()
def initialize() {
log.debug "initialize"
subscribe(thePico, "pushed", pushedHandler)
subscribe(theBulb, "switch", switchHandler)
state.pressNum = 0
def pushedHandler(evt) {
switch(evt.value) {
case "1":
log.debug "button 1 pushed"
if (state.pressNum == 0) {
log.debug "pressNum is 0, On"
bulbOn()
sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Turn bulb on")
state.pressNum = 1
} else if (state.pressNum == 1) {
log.debug "pressNum is 1, Nightlight"
theBulb.setLevel(1)
theBulb.setColorTemperature(2237)
sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Nightlight")
state.pressNum = 2
} else if (state.pressNum == 2) {
log.debug "pressNum is 2, Relax"
theBulb.setLevel(57)
sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Relax")
state.pressNum = 3
} else if (state.pressNum == 3) {
log.debug "pressNum is 3, Read"
theBulb.setColorTemperature(2890)
theBulb.setLevel(100)
sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Read")
state.pressNum = 4
} else if (state.pressNum == 4) {
log.debug "pressNum is 4, Concentrate"
theBulb.setColorTemperature(4292)
sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Concentrate")
state.pressNum = 5
} else if (state.pressNum == 5) {
log.debug "pressNum is 5, Energize"
theBulb.setColorTemperature(6536)
sendEvent(name: "on", value: "pressNum: $state.pressNum", descriptionText: "Set bulb to Energize")
state.pressNum = 1
break;
case "2":
log.debug "button 2 pushed"
if (theBulb.currentValue("switch") == "off") {
bulbOn()
sendEvent(name: "brighten", value: "", descriptionText: "Brighten bulb to on")
} else {
def lvl = getLevel(1)
log.debug "brighten to level $lvl"
theBulb.setLevel(lvl)
sendEvent(name: "brighten", value: "level: $lvl", descriptionText: "Brighten bulb to $lvl")
break;
case "3":
// todo: center button
break;
case "4":
log.debug "button 4 pushed"
if (theBulb.currentValue("switch") != "off") {
def lvl = getLevel(0)
log.debug "dim to level $lvl"
if (lvl == 0) {
bulbOff()
sendEvent(name: "dim", value: "", descriptionText: "Dim bulb to off")
} else {
sendEvent(name: "dim", value: "level: $lvl", descriptionText: "Dim bulb to $lvl")
break;
case "5":
log.debug "button 5 pushed"
bulbOff()
sendEvent(name: "off", value: "pressNum: $state.pressNum", descriptionText: "Turn bulb off")
break;
default:
return
private bulbOn() {
theBulb.on()
theBulb.refresh()
private bulbOff() {
theBulb.off()
theBulb.refresh()
state.pressNum = 0
def switchHandler(evt) {
switch(evt.value) {
case "on":
state.pressNum = 1
break
case "off":
state.pressNum = 0
break
private int getLevel(typ) {
def lvl = theBulb.currentValue("level").toInteger()
log.debug "current level: $lvl"
switch (lvl) {
case 0..10:
lvl = 0
break
case 11..30:
lvl = 20
break
case 31..50:
lvl = 40
break
case 51..70:
lvl = 60
break
case 71..90:
lvl = 80
break
default:
lvl = 100
break
log.debug "adjusted level: $lvl"
if (typ == 1) lvl = lvl + 20
else lvl = lvl - 20
if (lvl > 100) lvl = 100
else if (lvl <= 0) lvl = 0
log.debug "new level: $lvl"
return lvl
