Hate to be a newbie with Hubitat...but need some q's answered
I have WD-200 dimmer, using supplied driver.
Current States
  • doubleTapped : 2
  • held : 1
  • level : 55
  • numberOfButtons : 12
  • pushed : 2
  • released : 1
  • switch : off
State Variables
  • lastLevel : 0
  • blinkval : 0
  • bin : -1
  • statusled4 : 2
  • statusled3 : 0
  • statusled2 : 0
  • statusled1 : 7
  • statusled7 : 7
  • statusled6 : 0
  • statusled5 : 0
  • manufacturer : HomeSeer Technologies
  • 1 : 0
  • 2 : 0
  • flashing : false
All 12 possible buttons (4 different taps plus hold and release x 2)
And you can control all leds.
With 300 I only see 2 taps in my log with the default drivers...anything more than that just gives a cryptic message. I'm trying to see what support I have moving from HS4 to Hubitat. I also only get double tapped as a selection of # of taps in rule machine. I will take a 200 out of HS4 and add it to Habitat to see what happens tomorrow. THANKS!
** 2023-10-04 05:23:26.759 PMdebugparse:zw device: 07, command: 5B03, payload: 14 82 01 , isMulticast: false
dev:32023-10-04 05:22:43.215 PMinfoKitchen button 2 doubleTapped
dev:32023-10-04 05:22:43.206 PMdebugparse:zw device: 07, command: 5B03, payload: 13 83 02 , isMulticast: false
dev:32023-10-04 05:22:41.800 PMinfoKitchen button 1 doubleTapped**
System drivers never support more than doubleTapped events. That's why I said up above you will need the custom driver.
Item 5, yes! There is a good integration between Hubitat and Harmony devices, although I'm able to do almost everything I do with my Harmony Touch/Harmony Hub with a simple Broadlink RM3 Mini integrated to Hubitat.
Item 6, yes. Marantz with Ethernet port are officialy supported.
THANKS!!! That's great to hear. All good to know!
