ogiewon
November 14, 2020, 10:38pm
5
You can use HubDuino to easily build a low cost illuminance sensor using a NodeMCU. HubDuino supports a variety of light level sensors, documented in the ReadMe.
Announcing the release of HubDuino v1.1.7 (aka ST_Anything for former ST users)
[UPDATE 1.1.9] This is a minor release to improve support for the latest ESP8266 and ESP32 Arduino IDE Board Support Packages.
[UPDATE 1.1.7] This is a significant update to the Parent Drivers. Changes include:
MAC Address no longer required when setting up a Parent Device. Only the IP Address/Port is required to help simplify initial startup. This also means that the micro-controller can be replaced with di…
