Good call!
Problem resolved. Even with diagnostic reboot, I couldn't get it to go from 134 to 137. Finally chose roll back to prior version from 134 and it gave me the choice of 137 or a 2.2.8.156 build. I chose 137 and it completed properly. @672southmain thanks for the pointer to diagnostics
For me, the first time I had an issue with it hanging like this I went into diagnostics and reverted back to 2.28. I preferred to wait until the hanging issue was resolved in the firmware before I tried updating again.
I saw that announcement for the .135 software that fixed the bug but may still hang when trying to install it so I waited.
When the .137 update was released I tried going from 2.28 directly to that and it worked fine without hanging. Plus it doesnโt still tell me that thereโs an update so it seems all is well at this point.
OK, here's just a heads up. The next incriment to .137 on the unit that's been hangin... Although I was expecting to have to revert to previous as before, it appeared to come up fine.... However, several hours later I realized the UI was fine, I could fiddle nobs and buttons, they responded accordingly, i.e. I turned a switch off in a dashboard, it showed off, and in the devcie page it showed off as well, but the device didn't respond. Puzzled, I finally did a revert to prior, picking .137 (and by the way that title is a little disorienting as I can pick a future update...) and after the associated reboot it was fine again. So UI looked to reboot and be fine, but the underlying engine,... she was caput.
I understand that should be the last of such issues per @gopher.ny 's post above, but thought others may find this helpful.
And again, Sorry to report @gopher.ny , update from .139 to .140... same issue, same hub, same fix.
