Hampton Bay Zigbee Controller - Intermittent Connectivity - Resolved
This.
The thread in the ST forum for this device is up to about 750 posts I think. A significant proportion of those is people reporting intermittent connectivity issues, and the answer is usually, “add a zigbee repeater.”
:point_up::point_up::point_up:
Everything I have is in the same room at this point:
  • Hampton Bay Zigbee Fan Controller
  • Hubitat Elevation
  • GE Zigbee Plug
  • Lutron Hub
  • Pico Remotes
I believe the connectivity issue is mostly between the Zigbee network and the Fan Controller.
Going to try moving the GE Plug to the other side of the room, farther from the HE but, about the same distance from the Fan Controller.
??? Which device is this?
Maybe this one?
https://byjasco.com/products/ge-zigbee-plug-smart-switch
Operating ceiling fans are frequently subject to intermittent drop offs just because the moving fan blades make it difficult to get signal through to the radio in the housing. The problem is worse if the fan blades are metal.
I usually recommend trying one of three things:
  1. if possible, put a zigbee repeater on the floor above the fan. These are 360° signals, and it's quite often easier to get through from above. Obviously this depends on the layout of the house.
  2. make sure the room has two Zigbee repeaters, not just one, at 90° to each other. This doesn't always help since the position of the blades is random when the message is coming through, but sometimes it does.
  3. in really stubborn cases you may be able to extend the antenna out from inside the housing. But this can be very tricky and while I know some people have done it successfully, I don't usually recommend it.
Yes.
Well, at least my blades aren't metal. I haven't kept detailed records, but I seem to notice it more when I come home and try to turn the fan or light on.
While I can't get one directly above it, as that's attic space, I could get one above and maybe 6' to the side. Had not thought of doing this.
Was wondering about this, just didn't want to go this route without some idea that it might help. Don't follow what you mean by "90° to each other"?!?
The antenna isn't extended,, but it does protrude from the fan housing. The install instructions state the antenna should be exposed, I modified the install in order to suit the near ceiling mount of the fan.
I also just relocated the GE ZigBee Plug-In Smart Switch | Jasco to the other side of the room.
If one repeater is on the north wall, put the second one on either the east wall or the west wall. Not the south wall.
One floor up and 6 feet over is fine, it doesn't have to be right above it.
Since the antenna extends anyway, put one of the repeaters on the side of the room That the antenna extends towards.
Back from trip over the weekend, picked up a GE ZigBee Plug-In Smart Dimmer | Jasco early in the week and installed it about 6’ away from and in line with (in same plane) as the Hampton Bay. Since then I’ve had 100% connectivity as far as I can tell.
Of course the dimmer is unhappy about the 5 bulbs in the lamp it’s controlling, so have to sort that out. That should be fairly straight forward though.
This is a bit old, but I thought I would contribute something I did to help this device work better.
The stock Zigbee antenna seems weak in general. I went to Amazon and purchased two new Zigbee/2.4 GHz Wireless antennas. The one was a small leaflet, like you would use internally in a Wifi router. The other was a more proper antenna on a printed circuit board. (links below) Both were about $8 each, so not expensive to try.
The controller box opens up with two screws, and you just pop the old antenna off and new one on.
The smaller leaflet worked better than the stock antenna, but still was not the best. I liked the fact it matched my fan canopy and downrod color so it was more inconspicuous than the stock or the other aftermarket antenna. The antenna wire was tiny, which helps to get it out of the canopy without pinching it. This has a very long flexible lead and has both the white and black antenna included.
The larger PCB style antenna seems to have much more gain than the others. It was the clear winner of the three. It is a bit ugly, but I think a bit of paint would help disguise it without attenuating the signal. For now I just left it "naked". The wire was a bit larger than the one above, but still much smaller than the original antenna lead. The lead on this is longer than stock but much shorter than the first antenna. The lead is stiff enough to support the antenna without tape or anything.
small leaflet:
larger PCB:
Continuing our discussion from the other thread here: Thanks for this information! I ordered the leaflet one and we'll see how it goes--and how well I'm able to get it to blend into my ceiling (which despite being white, I'm not sure the included one does a good job of, either; this one looks thin enough that I might be able to paint the wire and cover up the "leaf" part with a thin sheet of painted plastic or something, too--probably could just paint it directly but without seeing the part I'm hesitant).
Glad to hear it's not too hard to open. Wish I knew this before I installed it in the canopy, since I'll have to take it out now. People who just bought this and haven't installed it yet: consider yourself warned. :slight_smile:
@bertabcd1234 - how did things go with your antenna upgrade?
I cannot recommend swapping out the antenna highly enough. It has eliminated the "keep a repeater as close as possible" problem everyone mentions, has improved my LQI even though I've stopped doing that, and was pretty easy to do.
My LQI is 255, and my RSSI is -43 with the antenna swap. I don't have before numbers, but those numbers are very good if I am interpreting things correctly.
Most but not all of my devices are 255 LQI with a couple being as low as 238. My worst RSSI is -66 and the best is -43, so I think my mesh is pretty strong overall.
I decided to make a case for the wlaniot 2.4 Ghz antenna so it is protected. I found out the hard way that if the antenna touches GND while there is power to the circuit it will fry the Hampton Bay controller.
Here is my design on thingiverse:
Unfortunately, I discovered the grounding issues yesterday and blew two of my units replacing the stock antenna... I did all four at the same time and hadn't paid close enough attention to where I placed the new antenna... (New units on order)
Anyway, I have a question for all of you gurus... I initially replaced my antenna's with these...
https://www.amazon.com/gp/product/B08V4WDNXL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
But have decided to actually try these as they are better spec'd for this use..
https://www.amazon.com/gp/product/B077SVP7PN
Here is my question though... Could I PlastiDip them instead of the plastic cover idea? I'm thinking about coating them and then leaving it inside the canopy...
Either way, I have already seen an increase in performance just by replacing the stock antenna... I left the small Eightwood antenna inside the canopy also...
Can you please clarify what I need to watch out to avoid frying the controller? How does the case help?
With everything (all the wires) jammed up in the cowling, inadvertently, my substitute antenna lead wire was either too close or touched the ground wire... So when I applied power back to the unit, instantly it blew the board on the controller... So after ordering a replacement and then replacing all the antenna on the other controllers I have, I was very careful to make sure the wires were separated when stuffing it all back in and buttoning up the cowling... Initially I had a good experience with swapping out the antenna, in terms of connectivity and drop outs, but I still have one unit that drops off every so often and I have to power cycle to get it to come back... Because I have four fans in very close proximity and they are all the same, I'm beginning to believe there are issues with some of the boards... Out of the four fans, like I said, one has issues and the others don't... So I might end up replacing the controller on that one to see if it fixes things...
Thanks. To be clear I need to ensure the two exposed parts of the antenna, the U.FL connector and where the wire is soldered on the antenna, never touch ground, either grounding wire or grounded box/bracket/canopy, correct? I guess electrical tape on these parts could prevent that?
