Thanks Ken. I reset service data, unchecked Huroku but it is still asking me to paste the long link inside my server web config page. Sorry I don't know where that is for my server. I did not even know I can create a server! lol
Ok did that and saved. I go back to echo speak setup and get the following screenshots in that order C1, C2, C3, C4. Sorry I feel like a real pain in the neck! Thank you for your patience.
This will load the Docker into unraid and once you start it, you will be able to access the webui from http://(your IP address here):8091 and can use it to follow the instruction above.
So I am using unraid and this approach worked for getting to the config page on 8091, but as soon as I log into amazon and set the callback it says authenticated and when I go back to echo speaks on the hub it says "You still need to Login to Amazon to complete the setup" for some reason??? Any ideas?
@jtp10181
I'm using Docker on Unraid, with and without portainer. For some reason I get the server up, I can connect to IP:8091 , I clear the echo speaks configuration, uncheck heroku, I get the callback link, I connect no problem, login to amazon no problem, it says Authentication good, and when I go back to echo speaks on the hub i still see: "You still need to Login to Amazon to complete the setup." Under that I can see
Local Server: (Configured)
Server: (http://192.168.1.99:8091) (which is correct)
Domain: (amazon.com) (I'm US based so I assume also correct).
Yet the login just doesn't seem to stick? Any ideas? This happens whether I run the docker directly or through your helpful portainer script.
Log back in and DO NOT press Save at the bottom after logging in, just close the browser tab/window. I am pretty sure the Save button breaks the login.
Any other time that has happened usually restarting the container and then logging in without pressing save has worked fine, so not sure what the problem could be.
I'll keep messing with it. Think a fresh install of echo speaks would help? I've had it installed for years so just updated the cookie server nonsense, it'd be a pain to because my devices would get new device IDs i think which would throw off my custom makerAPI integrations on various devices, but if I need to do that I can.
