Have anyone else experienced Group and Scenes sometimes failing to work as intended?
Current use case:
Using Group and Scenes to group all devices within a room.
When activating night or leave home scene, each room will power down in succession (a big bang way of powering down all at 1 go fails 90% the time for me, hence the room by room method now).
One example of the Group and Scenes settings I used for a very small group of 2 devices...
The room Group switch turns off, but devices within the group sometimes do not turn off. Failure rate is rather low (guesstimate of ~10%) but not acceptable when intention is to power down all devices when leaving home.
Have deleted the group and recreated, but the bug continues to happen sometimes. This happens even if my group has only 2 devices.
Are these Zigbee or Z-Wave devices? I ask because you have setup metering, which shouldn’t be necessary for Zigbee, but also have “enable Zigbee group messaging” enabled. If these are Z-Wave devices, are you using ZWJS, or Z/IP. Also, what Hub are you using?
For Z-Wave devices, I have selected “on/off optimization”. This prevents off/on commands being sent to devices that are already off/on and clogging up the radio.
I have created a group device for all Zigbee devices that I want to turn off at once, and one group device for all z-wave devices. For the latter, I have on/off optimization and metering enabled. I don’t remember the last time a device didn’t turn off as requested.
Zigbee group messaging sends a broadcast message, no metering needed. I have a single group device for shutting off all of my downstairs Zigbee lights in one go. I never have lights left on.
