Drivers should not round if not asked. I don't think this is a dev problem. I have device drivers I've written, other devs' work I use, and HE drivers. When a generic sensor reports a temp and offers me a decimal place - 58.8 for example, it shows 58.8 on my tiles. But if the temp is 58.0 it shows 58 on the tile.
From my reading this seems platform specific - even references to Groovy library versions. HE should give me the option at the OS level and I shouldn't be forced to accept rounding up on .0 values. It throws off tile layouts, fonts etc and looks crappy. rant over.
This is what I am using in one of my drivers:
def temperatureEvent( temperature ) {
def map = [:]
map.name = "temperature"
map.unit = "\u00B0"+"${location.temperatureScale}"
String tempConverted = convertTemperatureIfNeeded(temperature, "C", precision=1)
map.value = tempConverted
if (settings?.txtEnable) {log.info "${device.displayName} ${map.name} is ${map.value} ${map.unit}"}
sendEvent(map)
infoMotion 3in1 _TZE200_7hfcudw5 temperature is 30.0 °C
There are definitely coding options to prevent the zero from being dropped regardless of what the value is representing. Something as simple as:
newStaticCharge = newStaticCharge.toBigDecimal().setScale(2,BigDecimal.ROUND_HALF_UP)
enforces maintaining two decimal places.
