Greece Hubitat?
Hello from Greece!
Is anybody from Greece?
I want to know if i can setup the hubitat at Greece standards?
Does anybody knows if the zwave products work at Greece standards?
I want to buy this, so it can control 4-5 spots lights :
GE Z-Wave Plus Smart Lighting Smart Dimmer Switch
This one to sent movement sensor to turn the above 4-5 sports lights on :
Aeotec Z-Wave Plus MultiSensor 6
And the hubitat hub to control those automatically.
Am i thinking right?
sorry for my bad English.
Welcome. You can use a Hubitat hub in Greece, just make sure you buy the model intended for use in the EU. Z-wave devices function on different frequencies that vary by region, so you’ll need to ensure you buy European versions; they operate on 868 MHz frequency.
Thank you!
I need help on my idea, i want, when i open the main door or the apartment, the lights(4-5 spot lights) of the hole to turn on automatically for some minutes.
What products will you recommend me to take?
I was thinking to take :
For controling the lights (spots of hole)
and or a sensor or door sensor for the hole.
I have several and they work extremely well. Where would you be buying the GE dimmer from? I may be wrong, but these may not be available with the EU frequency. Z-wave devices are specific to different regions around the world and must all match.
