I recently transitioned from the Graywind App / Hub to Hubitat. I selected the Yolax Motor Shade Driver. I'm pretty sure Graywind uses Yooksmart, but they appear to be similar. Everything successfully transitioned over except the battery level. I don't think the Yolax driver has a request to report battery level. Is it possible to get the source-code for this driver with some assistance to add battery level or request an update to the driver?
This device is a tuya clone, as such if it reports battery it could be stuffed into the manufacturer cluster EF00 me thinks, and we don't have this cluster decoded so there's not much I can do on this one.
Is there a way I can attempt to decode on my own or anything you might suggest I reach out to the manufacturer on? I know when I use the "Generic Zigbee Motor", it constantly reports 0 as battery. I don't mind putting in the extra work, just need to know where to start.
I reached out to Yooksmart inquiring about how to request it and this is what they sent me some images regarding the Zigbee spec and a trace using WireShark. Is this helpful at all for determining that modifications might be required?
