Govee APP and Devices
I have used the Govee Integration app for a bit now. I have 4 devices on this APP. I have one device that stopped responding recently. IT will work via the Govee app itself.
The event shows - Switch ON, Pending, Success --- strip doesn't respond.
I removed the devices and then added it back, still same issue. ALL other devices work accordingly.
Thoughts?
Keep in mind your phone can lean on bluetooth to connect to the device.
Is the device attached to wifi? Are you using the Lan control options or was left using the cloud API to control the device?
If you enable debug logging and try actions with the device what happens? Does anything show in logging?
Thank you @mavrrick58
IT appears that it lost the wifi but was operating via BT locally from phone. I was unable to get it back on wifi so I have opened a ticket wiht Govve for controller replacement.
