Google says Hubitat not available
I have a nighttime scene configured in HE. Turning on the scene does things like turn off lights, arm the alarms system, lock doors, turn of a/v stuff (via Harmony), make an announcement and set the thermostat to night time temperatures. When it is turned off it disarms the alarm, makes an announcement and sets the thermostat to morning temperatures.
In Google Assistant I have the goodnight routine configured so that the only thing it does is turn on the night time scene. The good morning routine turns off the scene.
When I activate the good night routine with "Hey Google, goodnight" everything happens properly, but after a couple of seconds, google responds that hubitat isn't availalbe, even though it activated the scene.
I do not get the error when running the good morning routine.
I have tried disabling all the different actions that happen when the scene is turned on, but I always get this error.
Looking at the logs, there are no errors and there is nothing from the Google Home app. There is a warning from the Harmony Hub about an unhandled response, but it went away when I removed turning off the A/V stuff from the scene but the error from google still happened.
At this point, I am not sure what else to try, so if anyone has suggestions, that would be great.
Thank you!
Logs
[dev:97](http://192.168.0.148/logs#dev97)2019-01-06 11:47:20.262 am [info](http://192.168.0.148/device/edit/97)Front Door Lock was locked by digital command
[dev:97](http://192.168.0.148/logs#dev97)2019-01-06 11:47:20.259 am [debug](http://192.168.0.148/device/edit/97)parseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 20 01 0101FFFF0075A7C42300, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:20, direction:01, data:[01, 01, FF, FF, 00, 75, A7, C4, 23, 00]]
[dev:97](http://192.168.0.148/logs#dev97)2019-01-06 11:47:19.182 am [debug](http://192.168.0.148/device/edit/97)parseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
[dev:97](http://192.168.0.148/logs#dev97)2019-01-06 11:47:19.169 am [debug](http://192.168.0.148/device/edit/97)parseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
[dev:97](http://192.168.0.148/logs#dev97)2019-01-06 11:47:19.164 am [debug](http://192.168.0.148/device/edit/97)parseCommandResponse: [raw:catchall: 0104 0101 01 01 0040 00 5A87 01 00 0000 00 01 00, profileId:0104, clusterId:0101, clusterInt:257, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5A87, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:01, data:[00]]
[dev:167](http://192.168.0.148/logs#dev167)2019-01-06 11:47:18.738 am [warn](http://192.168.0.148/device/edit/167)Unhandled response from Harmony Hub. json = {"cmd":"harmony.engine?helpdiscretes","code":200,"id":"0","msg":"OK","data":{"activityId":"-1"}}
[dev:167](http://192.168.0.148/logs#dev167)2019-01-06 11:47:18.707 am [warn](http://192.168.0.148/device/edit/167)Unhandled response from Harmony Hub. json = {"cmd":"harmony.engine?helpdiscretes","code":200,"id":"0","msg":"OK","data":{"isHelpDiscretes":"true","done":"4","total":"4","deviceId":"49195061"}}
[dev:167](http://192.168.0.148/logs#dev167)2019-01-06 11:47:18.006 am [warn](http://192.168.0.148/device/edit/167)Unhandled response from Harmony Hub. json = {"cmd":"harmony.engine?helpdiscretes","code":100,"id":"0","msg":"Continue","data":{"isHelpDiscretes":"true","done":"3","total":"4","deviceId":"49195062"}}
[dev:39](http://192.168.0.148/logs#dev39)2019-01-06 11:47:17.949 am [debug](http://192.168.0.148/device/edit/39)ParseEx returned [[value:fanAuto, name:thermostatFanMode, displayed:false]]
[dev:174](http://192.168.0.148/logs#dev174)2019-01-06 11:47:17.293 am [info](http://192.168.0.148/device/edit/174)Living Room Home volume is 100
[dev:174](http://192.168.0.148/logs#dev174)2019-01-06 11:47:17.263 am [info](http://192.168.0.148/device/edit/174)mediaSourceEvents:Hubitat
[dev:39](http://192.168.0.148/logs#dev39)2019-01-06 11:47:17.072 am [debug](http://192.168.0.148/device/edit/39)ParseEx returned [[value:64, unit:F, displayed:false, name:heatingSetpoint], [name:thermostatSetpoint, unit:F, value:64]]
[dev:167](http://192.168.0.148/logs#dev167)2019-01-06 11:47:17.049 am [warn](http://192.168.0.148/device/edit/167)Unhandled response from Harmony Hub. json = {"cmd":"harmony.engine?helpdiscretes","code":100,"id":"0","msg":"Continue","data":{"isHelpDiscretes":"true","done":"2","total":"4","deviceId":"49195198"}}
[dev:162](http://192.168.0.148/logs#dev162)2019-01-06 11:47:17.046 am [info](http://192.168.0.148/device/edit/162)Master Bedroom Mini volume is 100
[dev:162](http://192.168.0.148/logs#dev162)2019-01-06 11:47:17.016 am [info](http://192.168.0.148/device/edit/162)mediaSourceEvents:Hubitat
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.713 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Exit Delay in Progress
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.712 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Stripping Checksum: 6561
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.712 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Time Stamp Not Found
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.711 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Preprocessing Message
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.710 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Parsing Incoming message: 6561D2
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.634 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Keypad LED State - partition 1
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.633 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Stripping Checksum: 5108B
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.632 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Time Stamp Not Found
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.630 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Preprocessing Message
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:16.629 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Parsing Incoming message: 5108B10
[app:168](http://192.168.0.148/logs#app168)2019-01-06 11:47:16.382 am [info](http://192.168.0.148/installedapp/configure/168)Armed Home Triggered
[dev:174](http://192.168.0.148/logs#dev174)2019-01-06 11:47:16.276 am [info](http://192.168.0.148/device/edit/174)mediaSourceEvents:Hubitat
[dev:174](http://192.168.0.148/logs#dev174)2019-01-06 11:47:16.275 am [info](http://192.168.0.148/device/edit/174)Living Room Home volume is 51
[dev:162](http://192.168.0.148/logs#dev162)2019-01-06 11:47:16.087 am [info](http://192.168.0.148/device/edit/162)mediaSourceEvents:Hubitat
[dev:162](http://192.168.0.148/logs#dev162)2019-01-06 11:47:16.084 am [info](http://192.168.0.148/device/edit/162)Master Bedroom Mini volume is 40
[dev:167](http://192.168.0.148/logs#dev167)2019-01-06 11:47:16.060 am [warn](http://192.168.0.148/device/edit/167)Unhandled response from Harmony Hub. json = {"cmd":"harmony.engine?helpdiscretes","code":100,"id":"0","msg":"Continue","data":{"isHelpDiscretes":"true","done":"1","total":"4","deviceId":"49195063"}}
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:15.963 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Command accepted
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:15.962 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Stripping Checksum: 500031
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:15.961 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Time Stamp Not Found
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:15.960 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Preprocessing Message
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:15.959 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Parsing Incoming message: 50003129
[app:169](http://192.168.0.148/logs#app169)2019-01-06 11:47:15.889 am [info](http://192.168.0.148/installedapp/configure/169)Disarmed: Home hsmStatus armedHome
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:15.883 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: 0311C5
[dev:65](http://192.168.0.148/logs#dev65)2019-01-06 11:47:15.882 am [debug](http://192.168.0.148/device/edit/65)Envisalink Integration: Arm Home
[app:167](http://192.168.0.148/logs#app167)2019-01-06 11:47:15.846 am [info](http://192.168.0.148/installedapp/configure/167)Armed Away: Home hsmStatus armedHome
[app:65](http://192.168.0.148/logs#app65)2019-01-06 11:47:15.844 am [info](http://192.168.0.148/installedapp/configure/65)HSM Alert: armedHome
[app:168](http://192.168.0.148/logs#app168)2019-01-06 11:47:15.843 am [info](http://192.168.0.148/installedapp/configure/168)Armed Home: Home hsmStatus armedHome
[app:101](http://192.168.0.148/logs#app101)2019-01-06 11:47:15.737 am [info](http://192.168.0.148/installedapp/configure/101)Nighttime is now True
[app:3](http://192.168.0.148/logs#app3)2019-01-06 11:47:15.718 am [info](http://192.168.0.148/installedapp/configure/3)Armed Home
[dev:39](http://192.168.0.148/logs#dev39)2019-01-06 11:47:15.619 am [debug](http://192.168.0.148/device/edit/39)setCoolingSetpoint(72.0)
[dev:39](http://192.168.0.148/logs#dev39)2019-01-06 11:47:15.601 am [debug](http://192.168.0.148/device/edit/39)setHeatingSetpoint(64.0)
[dev:167](http://192.168.0.148/logs#dev167)2019-01-06 11:47:15.568 am [debug](http://192.168.0.148/device/edit/167)stopActivity() called...
[app:101](http://192.168.0.148/logs#app101)2019-01-06 11:47:15.496 am [info](http://192.168.0.148/installedapp/configure/101) --> Nighttime on [true]
[app:101](http://192.168.0.148/logs#app101)2019-01-06 11:47:15.430 am [info](http://192.168.0.148/installedapp/configure/101)Nighttime: Nighttime switch on
You could always use Google to turn on a momentary virtual switch and use this switch to turn on your hubitat scene.
(A separate switch for night & morning)
That way Google is just controlling the switch which should report it’s status to google in a timely manner.
Andy
Thank you. That works. I created two virtual switches that turn back to off after a delay.
I wouldn't have thought of that.
