Google Home will not sync with Hubitat
Google home will not sync with my C8 hubitat. I can select my hub from the google home app. I select a couple of devices and hit authorize. The app says "Hubitat is linked" and then a few seconds later it says "Something went wrong, try again". None of the devices were added to google home.
Everything was working fine. I left home for about 9 days and I set up a new Hubitat at my daughter house. I have access to two different Hubitats now. When I came home I no longer had any devices in my Google home. I try to sync again and I get the above error. I rebooted the Hubitat and that did not help. Any ideas?
By the way, my Hue Bridge is still working fine with Google home.
I also went to the Google Home webpage, went to security, and then unlinked Hubitat there. That also did not solve the problem
One Google or Amazon account per hub.
You can share an account using HubMesh to bring the devices to a common hub and THAT hub does all the communications. You said in your other topic that your homes are in different states and thus HubMesh is not an option for that situation.
