Google Assistant Relay [cc] confusion
I just set up GAR 3.3 with hubitat driver v2 and it seems to be working correctly but I am running into a frustrating problem.
I can't seem to get some [CC] commands to work.
I mainly set this up so I can automate turning on and off my cromcast enabled tv's (and shield).
"[cc] turn off my [location] tv" works
"[cc] turn on my [location tv' does not work.
checking my google activity looks like this:
I am getting to same behavior when I run these commands directly from the GAR sandbox as well
Is there something I'm missing?
Please try again using "[CC]" as your prefix, instead of "[cc]". The driver is looking for an exact match, and in this case the characters need to be in UPPERCASE. :wink:
I should have known better.
this is exactly my problem. you are a genius. Thanks!
