New WD500Z5-1 dimmer using Generic Smart Dimmer driver, only 1 ML rule turns it on/off when in Home mode, setup to dim to 75% with motion, yet my logs show many different values except for 75% until I hit refresh in the device window, then 75% is noted. 40% is pretty common, 51% has been seen as well as a few other values
Just want to check, but are you absolutely positive there's not a rule that uses the switch. You've check in the device under "used by" and didn't find any other rules listed? Just want to make sure you verified that as wel.
I do know that your dimmer won't ever show 100% I've seen it explained here a few times, but I can't tell you why. Mine don't ever show 100% either. That is the driver and dimmer and how it works. The 40% is the value in question. Is the light actually stopping at 40% when setting it? Or is it just logging that? Have you experienced an actual incorrect level?
I'm thinking out loud here, but do you think it's possible that it's a reporting stepping stone? That it's not completing the final report to the hub for whatever reason?
[EDIT]
I just had a conversation with someone that kind've said the same thing. The reliability of the mesh. Now I would think to have a pretty robust mesh as most of my mains are zwave and zwave plus and my house footprint is not that large, but this was also about a lock. Doing almost exactly that.
But it does not register any of these values in the light. And it logs 75% in the logs but the events show numbers all over. These are only ever at 100% or off
Looking at your rules, turning it up works, can't you just use motion to turn off the virtual switch when motion is stopped again in your RM rule? Then the motion lighting rule will trigger because the VS is off and turn off the light?
[EDIT]
If someone turned it up, then why would they turn it back down before they leave? I think you should use a different trigger to reset that part of your rule like the motion sensor. IMHO
Yes motion will turn it off after the delay. Then a few mins later go back in and have to manually dim up again. Was hoping to pause the original ML rule with a dim up action... and we would only turn off the light IF we manually turned it on, otherwise motion would prevail
Apparently Pause in ML doesn't work the same way as it does in RM
