Gocontrol sensors
Can someone help me out, I just added some gocontrol sensors and they show as generic contact but it does s
how open or close status
Click on configure.
You need to find this driver and install it.
I suggest you do the RAW import method.
I flash about 3 and 2 of them are showing open. When they are close
Thanks, I didn't know about @krlaframboise's driver. I'd been using the generic system z-wave contact sensor driver. Kevin's driver gives more details and configurability.
Yes, it gives you a lot more usability including being able to utilize the external sensor function.
Here is the link for the multi function sensor as well.
Do you have any Z-Wave repeaters paired to your Hubitat Elevation hub yet?
How far away are these contact sensors from the hub?
Mine are fairly close to my hub. I created a 3 way switch situation to control a zigbee bulb on the stairway landing.
I got mine working, but they are backwards right now. The sensors show open when they are closed. Any idea how to swap this from Hubitat?
Have you woken up the device and then clicked CONFIGURE on its device details page? It may help to configure the device reporting settings.
I initially tried clicking the CONFIGURE button but nothing came up. The resolution was physically hitting the devices a few times and they returned to normal statuses.
