I’m running into some trouble with my GoControl Garage Door opener. It had previously worked with an old garage door. I bought a new door, the installers didn't hook up the GoControl. It's a simple device to connect so I thought no big deal. Now I'm close to adding it to the drawer of shame, but decided to ask the community for suggestions before doing so. I’ve copied the device log entries below.
Using generic z-wave driver, this is the log messages when I hit open on the device page.
dev:21872020-02-01 11:29:18.979 pm debug zw device: 22, command: 9881, payload: 00 71 05 00 00 00 FF 06 44 00 , isMulticast: false parsed to ['displayed':true, 'descriptionText':Generic Z-Wave Garage Door Opener unable to perform requested operation (UL requirement)]
dev:21872020-02-01 11:29:18.970 pm info Generic Z-Wave Garage Door Opener unable to perform requested operation (UL requirement)
dev:21872020-02-01 11:29:18.965 pm debug NotificationReport- NotificationReport(v1AlarmType:0, v1AlarmLevel:0, reserved:0, notificationStatus:255, notificationType:6, event:68, sequence:false, eventParametersLength:0, eventParameter:[])
dev:21872020-02-01 11:29:18.313 pm debug zw device: 22, command: 9881, payload: 00 66 03 00 , isMulticast: false parsed to [['name':'contact', 'value':'closed', 'displayed':false], ['name':'door', 'value':'closed', 'descriptionText':Generic Z-Wave Garage Door Opener is closed]]
dev:21872020-02-01 11:29:18.301 pm info Generic Z-Wave Garage Door Opener is closed
dev:21872020-02-01 11:29:18.297 pm debug BarrierOperatorReport- BarrierOperatorReport(barrierState:0)
Device data :
- deviceType: 18244
- zwaveSecurePairingComplete: true
- inClusters: 0x5E,0x5A,0x72,0x73,0x98
- deviceId: 13616
- manufacturer:
I’ve changed the battery in the tilt sensor, done a z-wave exclude, reset the device (press button 5 times; it beeped; should be reset), in-place secure pair, manual open & close to sync. The device page correctly shows open or closed. I emailed Linear Support last month and received no response. It appears to be some sort of safety feature? I can’t find any reference in the garage door documentation.
Any thoughts?
