I am moving from ST to HE and I have a cranky garage door opener.
I have 2 GoControl openers, both paired fine but one works and the olther one doesn't do anything.
I have excluded and re-paired 3 times with no issue but it just doesn't do anything. I am using the Generic driver for both.
Guesses?
EDIT: Well it looks like you have to wait 5 minutes. I did this post and hit open more than 5 minutes later and I heard the door functioning and events are now there.
Odd.
I saw the same behavior with Kiwkset locks (on a C-5). When paired, it looks like everything is done, but you have to wait for a bit before they will accept commands (I let mine sit for about 10-15 minutes just to be safe!)
Cycling fixed my garage one but my shed one is now on the fritz.
I works in every way except you have to press Refresh on the device page to get the events.
I changed the tilt battery just because it was a little under 3 VDC but no diff.
I will have to move the hub close and exclude and re-add as the next step.
I'm not out of range as all the commands work but the exclude is being fussy.
