Request - Iād like to be able to set a delay pending cancellation on a global variable.
Here is my use case - I have two motion sensors on opposite corners of my great room. One of the motion sensors is a bosch motion sensor that reduces activation with pets, the other is an iris V2. I want the lights to turn on only when both motion sensors are activated and then turn off when both are inactive after a delay of 4 minutes, pending cancellation.
I have a GV set by a trigger based on activation of the bosch motion sensor. then I have a rule that evaluates that GV and the activity of the other motion sensor and turns the lights on. then when false it turns off the lights after a delay.
I want it to turn off the GV after a delay pending cancellation also.
I have tried motion zone controller with triggered activation, but this does not evaluate the current value of the second motion sensor, it just triggers a window and then if the other sensor turns active it turns on.
I also recognize that motion lighting allows for something like this, but I want to be able to control this rule with other rules.
thanks
