Hi Folks, my GLEDOPTO GL-C-009P stopped to works, so I want to pair again, but the only place I found information about the reset is it below, I tried this but did not work, could you guys give some advice?
Pairing
- Switch on your device.
- Now switch off and on within 2 seconds.
- Repeat off/on four times.
- Reset is done when the device is switched on in the fifth time and the light stays on after blinking 4 times
