Friends at Hubitat. I bought a house with Hubitat and everything wired. I am digging into learning the system. I currently have it loaded on my IPAD. I would like to also add it to my Macbook Pro, as is it will be much easier to work with. Where can I find instructions to download Hubitat to my Macbook and how to connect it to my system?
You don't need an app for this; the admin interface is just a web page (similar to that of many routers, network printers, etc., you may have worked with in the past). Typing the IP address of your hub into the address bar of your web browser should work, or if you don't know what that is, use http://findmyhub.hubitat.com to find it (keep in mind that this may change every so often if you don't have a static or reserved IP address for your hub).
Perfect. It worked like a charm. Many thanks.
You may find the Chrome experience to be better than Safari. For me it's zippier, not sure why.
