Does anyone know how to remove a corrupted Rule Machine 4.0 rule?
I have run into a problem yesterday... I was creating a rule and decided to modify a variable from Number to Decimal.
I deleted the existing variable and re-created a new one with the same name, but setup as a Decimal.
At one point as I was doing this, I got an "Unexpected Error" and now I can no longer to into the rule to delete it. I think it is still running though which is a problem because it is now doing things it shouldn't...
Here's a screenshot of the error:
The logs say:
error java.lang.NullPointerException: Cannot get property 'val' on null object on line 654 (mainPage)
