I'm getting debug errors when trying to manually switch on and off Osram bulbs.
This of course also happens when running automations. Any suggestions?
In the devices tab, does this device have debug logging on?
Yes.
Turn it off, it is only needed if you are trying to chase an error. In fact, you can turn off text logging if you wish.
Oh, and if you just installed this device, debug logging should automatically turn of after IIRC 20 minutes or so.
Won't that just mask the problem if one exists?
Well I guess, but your logs don't show any errors. This is basically just the raw data you are seeing.
Errors are pretty clearly labeled "Error" and are bright red. Here is one I occasionally get:
2020-04-06 08:00:25.400 pm [error](http://192.100.0.000/installedapp/configure/104)Error making Call to Alexa message gateway:
Ok. I assumed since it said debug that it was an error. I appreciate you clarifying that.
