Get datatype?
Is there a way in an app to determine the datatype (string, integer..) of a variable and put type into a string variable? I know this is possible in C++.
Use the getClass() method.
variablename.getClass()
I previously tried that unsuccessfully.
Sorry, you want getObjectClassName(Object o)
Will that work for the basic data types, or whatever they are called (over 20 years since I learnt Java :slightly_smiling_face:). By that I mean variables that are not a pointer to an object.
Heck if I know :joy:. Victor added it because the getClass() was blocked.
You have an example of some working code?
VariableA pulled into RM from hub variables, no idea if its a integer or string
String B = getObjectClassName(VariableA) ??
Looks like String to me.
I want to determine if VariableA is a string or integer from inside app.
Just do
getObjectClassName(variableA)
OK we set now! Thanks.
String VariableB = getObjectClassName(VariableA)
VariableB returns java.lang.String
String VariableB = getObjectClassName(VariableA).replace("java.lang.", "")
VariableB returns String
