Get Battery level of Fire Tablet to control power on / off
I don't have a Fire and I have read on here that their OS isn't exactly Android and some apps don't work on a Fire tablet.
Now on to the fun.....
First, I recommend doing all of this on your phone so you can copy & paste the endpoints or HTTP Requests. There are 2 options..... 1) Use RM and Local Endpoints which allows you to do anything you want, not just turn off a single plug, light, etc. or 2) Use Maker API.
For OPTION 1....
  1. Create a Rule for TURN OFF PLUG in RM
  2. Trigger is Local Endpoint since your tablet will presumably always be home. Copy this Local Endpoint to your phone.
  3. Action is Turn Off Plug
  4. Now go to Tasker --> New Profile --> State --> Battery Level --> Choose the range for when you want plug to turn off. I set mine From 85 To 100.
  5. Create the Task for that Profile. Step 1 (and only) is HTTP Request with Method of GET. Paste your Local Endpoint into URL
  6. Click Back Arrow
  7. Hit Play Button at bottom left corner of screen to make sure Task does what it is supposed to do.
  8. Repeat steps 1-7 for TURN PLUG ON and set Battery Level From 0 to 30 (or similar).
For OPTION 2...
  1. Install Maker API (if you haven't already)
  2. Check the plug that you are using is selected in Maker API
  3. Copy the URL for Device Command that should look something like this: http://HubitatIPAddress/apps/api/3/devices/[Device ID]/[Command]/[Secondary value]?access_token=xxxxxxxx-xxxx-4xxxx-xxxx-xxxxxxxxxxx. In yours, the "3" will be the app number for your Maker API instance so it will probably be a different number. To get the DeviceID, you can open the device screen on your computer browser and the DeviceID will be in URL.
  5. Create the Task for that Profile. Step 1 (and only) is HTTP Request with Method of GET. Paste the URL from Maker API. Change [DeviceID] to the DeviceID for the plug you want to change; Change Command to off; delete [Secondary value] so your final should be something like this: http://HubitatIPAddress/apps/api/3/devices/655/off?access_token=xxxxxxxx-xxxx-4xxxx-xxxx-xxxxxxxxxxx
  6. Repeat steps 4 & 5 but create New Profile with Battery Level of 0 to 30 (or similar) for turning on plug and your new URL will be http://HubitatIPAddress/apps/api/3/devices/655/on?access_token=xxxxxxxx-xxxx-4xxxx-xxxx-xxxxxxxxxxx
Let me know if I left something out. I apologize if I did. Writing the instructions is harder than actually doing this.
The benefit of Option 1 is that you can have multiple actions whereas Option 2 is only able to change one device per HTTP request.
