In my app the geofence is about a mile from the actual location of the hub. I'm not sure how the geofence is set but I can't find anyway to update it. Even on the widest setting it doesn't reach anywhere near my home.
Is there a way to update the geofence in the app or on the hub itself?
Mine matched up with my hub’s location as it was set in the web admin interface without me having to do anything.
But if you tap and hold the pin in the mobile app, you can drag it to wherever you need it to go.
Thank you. I tried that like three times and the pin never moved but this time I pressed with conviction and it lifted right up. Apparently I didn't hold it long enough.
Had the same issue. Mine was showing up about 5 miles away. What I did was go to Google Maps to find my exact Lat/Long numbers, then entered them into the Location and Modes settings within portal.hubitat.com. I then had to log out of Hubitat on my phone and then log in and it seems to have finally corrected the issue.
