You can tap (hold) and then drag the pin to your actual location on the map in the app.
Did you set your hub’s location in the admin pages using a web browser? When that’s done, the mobile app should automatically set your hub’s location without having to manually move it in the app.
Thank you Mark for your message. This is what I just did: I opened google map on my cell and noted my long/lat exact of my house. I went to the hub with a browser and updated my location. The map of the hub settings shows my house correctly. I clicked Update. I closed and re-opened the app, I get a message at the top "Sent EXIT geoevent for current location. At the bottom it says Out of Geofence. The red dot is not at my house. Did I miss something? Thank you Mark.
Well, I was all excited about trying those Presence options. I have an IPhone 6. None of those Presence options can be installed on my phone because they all require IOS 13 or higher. My phone is up to date with 12.5 Any other options out there? Thank you.
It doesn’t sound like it. Not sure why the hub location didn’t update itself in the app. But you can still manually hold then drag the pin wherever you need it to.
We would need some more details to try to understand if your issue is at all related to OP’s question.
No idea what that error means far as geofence, but did you submit a trouble ticket to support?
Also, I assume your phone is added as a device to Hubitat? Does it show in the Devices section? Can you send yourself a text message via the Device Settings Page? Can you change state from Arrived to Departed on that phone's settings page? Not sure if any of that will help, but it might narrow down where the issue is.
