Geofence | iOS app | Wrong Location
Maybe I'm missing something but, geofence seems to be way out of whack (see image) when using the iOS app on my phone.
When using the iOS Hubitat app and select "Geofence", it zooms into a red pin somewhere far east of my actual location and says, "Out of Geofence".
My actual location is where the blue dot is as depicted in the image.
Any ideas?
I would recommend life360. I just use the free account and HE has a built in app to connect.
It uses less power on the iPhone (I have a iPhone 8) and it just works.
I do use the HE app for dashboards but I keep geofencing in the app disabled.
I don’t remember how I sorted it out, but I do remember having the same problem where it uses the middle of Kansas and not your home. Good luck
I think you can drag the pin to your location.
That worked. Thanks.
This. If you haven't ever done it you have to tell the hub where it is at least once. :stuck_out_tongue:
You need to hold the pin until it "kind of pops", then you can move it where you want it, in the Hubitat App / Geofence.
