Im using the generic zigbee driver with a sonoff zigbee mini. Worked fine for a long time. Appears a few HE updates ago. The light using the mini has decided to flash once then come. I also cannot us the select nothing option for flash. So is always set at 750. Its annoying and would like to stop the flash. If i can. Any ideas out there?
Are you saying that when the plug is turned on, the light connected to it flashes instead of turning on?
The Flash setting shouldn’t make the attached load flash unless the “flash” command is used. When the “on” command is used, it should just turn on…
The light gives one flash then turns on.
Have you tried changing bulbs?
No. This switch is for a set of dumb track lights. I have not changed anything.
Okay, that’s not normal behaviour. Do you have any way to move the switch to somewhere else and try it there? I wonder if the switch might be defective, or possibly incompatible with the light…?
@glenpond00 is this the no-neutral version of the sonoff mini-switch?
