I have a Generic 4 Channel Zigbee Switch I want to use as an irrigation control.
It's set up as Type Generic Zigbee Multi-Endpoint Switch and all channels are integrated and work. What i am looking for is a use app that will work with it to do simple irrigation control.
What are you looking for in an app? With each of the switches being exposed as a child switch device (that acts just like any other switch device on your hub), you don't need anything special for this (e.g., the fact that the parent device is a multi-endpoint Zigbee device doesn't matter).
A Basic Rule could do something simple like turn any of these devices on and off at a certain time, perhaps only if some restriction is (or isn't) met, though there are many other ways you can do something like this or something more complex. It all goes back to the question: how are you looking to automate this?
Yep the relays as generic switches are exposed as children. I thought someone had maybe had written a user app emulated a Irrigation controller but I figured I would end up just using the rule machine. It was a shot. But thanks.
I haven’t used this app but maybe it will work for you:
JUst set it up to run 4 zones tomorrow AM. Looks like it will do the trick and lends to a multitude of device timing. Looks like it will take the place of some Rules I have in place for other devices. I will report back . Thanks!
Is that the "MH-Cozy" device? I recall reading it didn't last long term, but don't recall the exact thread. I think it was @aaiyar who had feedback on the device
