Has anyone added Merkury RGB Bulbs? I think they are also called Geeni
I picked up a couple out of the Walmart bargain bin for $6 a piece. They are wifi so they will not directly integrate with HE. I set up some Alexa routines, mixing these bulbs and HE controlled bulbs. It works, but if you are sensitive to cloud timing issues, don't mix them.
I had these on my wishlist a while ago.
I'm ignorant to some things when it comes to communications.
If a device (Not saying geeni does) accepts simple HTTP PUT locally does Hubitat not have the ability to do that?
Maybe that doesn't work on a local network?
Just curious, don't want to derail too much, WiFi devices confuse me because they're so un-standardized...
I have a couple of there smart strips would be interested in direct integration as well. I'm currently using the google home relay server to send commands to these devices.
