GE Zigbee Driver Error
I was looking in my logs on my new GE Zigbee Dimmer Switch is triggering a lot of errors, seems to be trying to poll the device but coming up with an error. It seems to prevent turning off the light via room lighting if you manually turn on the light switch, but don't trigger the motion sensor. I did try to switch to Generic Zigbee Dimmer and came up with the same error.
You must have been using a custom driver for this at some point. While the error is harmless in terms of regular device operation, to stop it, go to Logs > Scheduled Jobs, find the job named "poll" listed for this device, and delete it.
This makes sense, these used to be Kasa lights which had to get polled, I replaced them with zigbee dimmer switches using the replace device function, but maybe the job didn't get removed when I did that. Thanks!
