I have been fighting with bathroom lighting levels for a few weeks. I attempted to use the Mode/Motion app, Basic Rules, Simple Rules, and Rule Machine. Nothing works right. Finally, I settled on just developing a Simple Rule similar to someone else's post for a different project. Nothing worked. I simplified the rule to
On Closed contacts, Set Level of light to 15%.
Nothing. This is nearly identical to two other working rules I have on the pantry and hall closets. Open Contacts, turn on light. Close Contacts, turn off. The difference is I am using a dimmer and the Set Level command. In frustration, I added the bedroom dimmer to see if I could isolate the problem. The bedroom dimmer worked just fine. Close the contacts, the bedroom light comes on and adjusts to the desired level. Hmmm. It is a GE Zwave dimmer.
In the logs, the rule shows it activating and sending commands to the dimmer. The dimmer logs them but doesn't actually work. See Logs excerpt below.
The odd thing is that dimmer does work from Alexa, the HE phone UI, and HE web UI. So, it accepts digital commands. Just not from a Simple Rule. The Mode/Motion app is hinky. Sometimes things happen, sometimes not. So, I am not including it here. One problem at a time.
PS
In Simple Rules there is a field called "Fade Rate," is that measured in seconds or minutes? Or, something else? I cannot locate it in the documentation.
Thank you in advance for any assistance.
Door Sensor Contacts log
dev:5502022-03-18 04:14:45.123 am infoMaster bath door Sensor was opened
dev:5502022-03-18 04:14:35.740 am infoMaster bath door Sensor was closed
dev:5502022-03-18 04:14:21.169 am infoMaster bath door Sensor was opened
dev:5502022-03-18 04:10:06.832 am infoMaster bath door Sensor was closed
dev:5502022-03-18 02:58:12.887 am infoMaster bath door Sensor was opened
dev:5502022-03-18 02:56:32.354 am infoMaster bath door Sensor was closed
dev:5502022-03-18 02:55:01.342 am infoMaster bath door Sensor was opened
dev:5502022-03-18 02:54:00.220 am infoMaster bath door Sensor was closed
Rule Log
app:8362022-03-18 06:48:19.715 infoTurn On & Set Level Bathroom Light, Bedroom Light when Master bath door Sensor Opened anti-Turn On & Set Level
app:8362022-03-18 06:48:15.129 infoTurn On & Set Level Bathroom Light, Bedroom Light when Master bath door Sensor Opened Turn On & Set Level
app:8362022-03-18 06:47:52.560 infoTurn On & Set Level Bathroom Light, Bedroom Light when Master bath door Sensor Opened anti-Turn On & Set Level
app:8362022-03-18 06:47:42.700 infoTurn On & Set Level Bathroom Light, Bedroom Light when Master bath door Sensor Opened Turn On & Set Level
app:8362022-03-18 06:46:00.499 infoTurn On & Set Level Bathroom Light, Bedroom Light when Master bath door Sensor Opened anti-Turn On & Set Level
app:8362022-03-18 06:45:54.714 infoTurn On & Set Level Bathroom Light, Bedroom Light when Master bath door Sensor Opened Turn On & Set Level
app:8362022-03-18 06:45:27.881 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Opened anti-Turn On & Set Level
app:8362022-03-18 06:45:24.601 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Opened Turn On & Set Level
app:8362022-03-18 06:44:37.027 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Closed Turn On & Set Level
app:8362022-03-18 06:43:33.550 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Closed anti-Turn On & Set Level
app:8362022-03-18 06:43:18.876 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Closed Turn On & Set Level
app:8362022-03-18 04:14:35.795 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Closed Turn On & Set Level
app:8362022-03-18 04:10:06.925 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Closed Turn On & Set Level
app:8362022-03-18 02:56:32.423 infoTurn On & Set Level Bathroom Light when Master bath door Sensor Closed Turn On & Set Level
Bathroom dimmer
dev:4042022-03-18 07:19:44.779 infoBathroom Light was turned off [physical]
dev:4042022-03-18 06:48:32.719 infoBathroom Light level was set to 40% [digital]
dev:4042022-03-18 06:48:27.666 infoBathroom Light was turned on [digital]
dev:4042022-03-18 06:48:13.166 infoBathroom Light was turned off [physical]
dev:4042022-03-18 06:48:04.508 infoBathroom Light level was set to 17% [physical]
dev:4042022-03-18 06:47:59.459 infoBathroom Light level was set to 19% [digital]
dev:4042022-03-18 06:47:54.445 infoBathroom Light was turned on [digital]
dev:4042022-03-18 05:38:46.633 infoBathroom Light was turned off [physical]
dev:4042022-03-18 05:35:32.502 infoBathroom Light level was set to 54% [digital]
dev:4042022-03-18 05:35:27.520 infoBathroom Light was turned on [digital]
dev:4042022-03-18 04:14:32.850 infoBathroom Light was turned off [physical]
Rule
