GE Embrighten Outdoor Smart 40 amp switch
Does this appear as two devices in Hubitat when using it at 120V? I had the older version of this (Intermatic) and it did in Homeseer but I see nothing confirming this for the new version. Thanks.
I have the GE Enbrighten 40 amp smart switch model 14285 and it appears as one device in Hubitat. I am using the Generic Z-wave Plus Switch driver, but I don't believe it would make any difference.
The manual does show it has terminals for 2 loads at 120V, but I assume it only has one contactor/coil, so both loads will be either on or off, therefore one device in Hubitat makes sense.
The manual does show that you can monitor energy for one load or both loads, depending on how you wire the terminals, but I am not monitoring this and the Generic Z-Wave Plus Switch driver does not include it. You would have to use another driver to monitor energy.
There is a GE 40 Amp Smart Switch driver according to the Compatible device list.
