So, I have been perusing the forum looking for anything that might address what I would like to happen and have not seen anything... My search skills may be lacking, but I have read dozens and dozens of threads over the last week since I received my HE. So far, EVERYTHING that I have wanted to do, someone has had a solution, so I don;t think I am breaking any new ground here with this one either.
I have a mix of GE 14294 dimmers and associated add on (2 way) switches, as well as the same switches by Honeywell (39350 and 39351). ALL of those switches have @JasonJoels amazing double tap drivers and seem to be working flawlessly.
That said, I would like to create a rule that would set the dimmer value to 15% when the mode is set to "Home-Night" which is a mode I have defined already.
The rule would need to be in play if the lights are off and someone physically pushes the on switch or executes the command through GH "living, dining, hallway, or game room lights on".
The rule should be freely overridden by < GH example> "living room lights 50%" or if the switch is physically double tapped.
Ultimately, what I am looking for, is when the hub is in night mode, lights off, then physically touching a switch, or telling GH to turn x light on, should limit or set the value to 15% unless over ridden as described above.
To simplify things if need be, the rule does not necessarily need to be mode specific. It can be in play 100% of the time for now, since I am a low light person. I do not like bright lighting pretty much any time, except when cleaning or cooking, so I would prefer to always have the lights start at 15% then require input to go higher through either method.
Again, all help genuinely appreciated !!
