GE 12729 Z-Wave Dimmer switch not reporting
My GE 12729 Z-Wave Dimmer switch is not automatically reporting state changes when the physical switch is flipped.
If I go into the dashboard and click "refresh" the state will update
I have tried with the Generic Z-wave Dimmer (the default) and with the GE Enbrighten drivers, same result.
Any thoughts on what is going on? I am trying to write a rule that turns on/off two other lights not physically controlled by the switch when the switch changes state, but cant get past this reporting issue.
The switch in question:
Side note, this exact same rule did work when I was on SmartThings
If that's not a Z-Wave Plus you may need to poll it.
what do you mean? I would need to manually go in and check that switch?
(Most/almost all) NON-plus dimmer/switch devices do not automatically send status updates to the hub when changed physically/locally. Because of that, you have to have the hub poll/refresh it periodically to keep the states in sync.
Real pain in the arse, and because of that I highly recommend replacing all NON-plus devices with plus models (regardless what hub they are being used on - not specific to Hubitat).
It was a happy day in my house when I removed and threw away the last of those GE dimmers/switches.
Thank you, I have installed the poller app and will see how that goes!
What do you recommend replacing it with?
Any zwave plus device that does what you want. :slight_smile:
Ge, inivelli, zooz are probably the most common.
Lutron Caseta (you will need the bridge though) They just work.... Barring that, inovelli
