Trying to setup up Gcal Search, thought I had everything set right. When I try to authenticate, I get this...
"Sign in with Google
Access blocked: hubitat.com has not completed the Google verification process
********@****.com
hubitat.com has not completed the Google verification process. The app is currently being tested, and can only be accessed by developer-approved testers. If you think you should have access, contact the developer.
If you are a developer of hubitat.com, see error details.
Error 403: access_denied"
Did I screw up somewhere, or is this normal? It's been about 20 hours since I did it
UPDATE
Problem solved, I had missed a setting.
