NoWon
February 22, 2019, 2:04am
6
I removed both of my Linear garage door openers and replaced it with Mimolite and magnetic door sensor and they work fine in Hubitat.
Should work the same for a gate.
@jeremy.akers
my mimolite is connected in parallel to the garage door switch as well. I use a magnetic switch hard wired to the mimolite to indicated open/closed.
@taylotr
I do not have a mimo2 and can not access smartthings website from work but you can try to copy the mimo2 device handler from smartThings and paste it into notepad and then at the top select replace and select replace all and change physicalgraph in the DH to hubitat
then copy all of the code and create a device handler
sh…
