To do the test, you can safely touch the two contacts with a jumper wire. This will confirm if your garage can just open with a relay.
When installing the final product though, if you're not comfortable with high voltage, then cut the power to the garage and install it. Alternatively just unplug the garage motor
So I got all the parts and got antsy so I went for it (didn't do the jumper test, but tell me if I should go back and start there).
Below are pictures of the install and the drivers/apps I added tonight. When I go into "Garage Door" (source is "user"), and I click "open", I hear clicks but the garage door doesn't open.
do you mean leave the two white wires attached to the #1 and #2 connectors as they were before I started, and just add the red and black wires also to #1 and #2 and then to R1?
I have a button next to the door. And I want to control the garage with HE, doesn't that mean I need a "switch"?
Isn't this what I did? Or did I do it backwards - Motor to SW1 and button to R1?
from your picture, you have the white wires on R1 and the red/black on SW1. the red and black are going into the garage motor...this is wrong
This is how you should be wiring it up.
Whether you put the wires as shown in the picture of put the wires in parallel on the motor, either way should still have the button work on the wall and the relay control it (via HE)
YES I HAD THEM BACKWARDS!! THANK YOU!! WORKS PERFECTLY!!
except... I had noticed that recently I wasn't getting my "Garage Door Sensor" Notifications like I was a few weeks back. I started looking into it then but lost track. Kept thinking it was an issue with my notification set up and was dismayed to realize, unlike Rule Machine, there are no logs for notifications.... However! tonight while opening and closing my door many times testing my new Relay (THANK YOU), I realized that my Aqara contact sensor was no longer appropriately assessing the open state. Is there a "best" way to re-configure it/reset it/troubleshoot it?
see if you can't connect an external connection to it and add a tilt sensor. that's what i did and i can tell when my door is closed or open (even partially open). if not, i'd recommend the gocontrol WADWAZ-1. it's z-wave and not z-wave plus though
I have a brand new Aquara Window/Door contact sensor - worked perfectly for weeks. Once the door opened 1-2 inches, immediately it would say "Open" and I'd get a notification. It has 100% battery, but is no longer registering as "open" anymore...
May have fallen off the network. Try going to Zigbee pairing, and re-pair the device. If it finds it again, then you need to find a way to keep it on the network.
Aqara are very picky about staying on the network in general.
doesn't the sensor connect to the aqara hub, and that's what connects to HE? I would still say get a proper zwave contact sensor. it strengthens your zwave mesh and removes the need to rely on intermediary hubs
As @neonturbo wrote, the Xiaomi Aqara and Mijia sensors a finicky. They are a proprietary Zigbee and they don’t like a weak Zigbee mesh one bit. There’s tons of info on the forum about them. You’ll find a lot with a search.
Some quick tips:
Add IKEA TRÅDFRI outlets. They are compatible repeaters
Keep other non-compatible mains powered (repeating) Zigbee devices off your network
Keep all Zigbee lightbulbs (except for Sengled) off your hub. Only connected via a Hue bridge or another hub is going to be compatible with Xiaomi Zigbee devices
