C8 pro version 2.5.1.143. When I updated this week my Alexa voice commands no longer work for my garage door have a ZooZ zen17 controls the garage door opener, using the garage door ZooZ app worked perfectly for years. Had it exposed to Alexa and was able to control it
Alexa app now shows the device as a switch/other and says a garage door type no longer eligible. Anyone have ideas how to fix it?
Roll your own Alexa command. Create a virtual switch in Hubitat that is the trigger for the door opening. Create a routine in Alexa such that if she hears "Alexa, upsy daisy", it turns the switch on. Create a rule that says when Alexa turns on the switch, it opens the door, and turns off the upsy daisy switch.
Do same for "Down dog" or some such.
No use trying "Open the pod bay door, please HAL". Alexa has a canned response for that which overrides the custom command. [Edit .. oh wow .. I haven't tried that in years but apparently that now works!]
I did this in Webcore for my home-built smart doggy-door (also controlled by a ZooZ zen17). I made it a virtual blind so I can say "Open/Close doggy door".
While I have a work around, its possible updates on 2.5.1.180 broke something.
I had a garage door that worked flawlessly for years (Zen17>zooz garage door opener app), enabled the child device to alexa and was able to open and close it, Alexa could also see the contact sensor so I could ask it if the garage door was open or not. While the virtual switch and a couple RMs (one to control the garage door plus one to sync the virtual switch to the status of the garage door) work, I no longer can have alexa check the status of the garage door. post update to 2.5.1.18, i stated receiving these warnings on the logs and alexa would not open the door. Thoughts?
