I have 2 C7 with login enabled and are meshed together. I have been getting mesh token invalid error. regeneration and logging security in and out doesn't fix the issue. Both on same vlan and had no prior issue. I am guessing it's a bug in the recent update. Please advise.
Don't think so, I have a similar setup along with I'm assuming loads of others and this is the first post. Could you post a screenshot of the logs and maybe your settings?
Have you tried it without security enabled as well?
Both hubs were updated? What version did you come from? A few version back the hub mesh was changed to use mDNS.
hi, both hubs are updated. It was updated from ...144
I have mdns enabled on vlan
router UDM Pro
unless something changed at router level. What setting and logs should I post?
How do I disable security?
Pardon my ignorance!
Thanks for prompt reply. Yea. Different. I did change them just in case and restarted. No change.
Itβs a dilemma. Have a lot of devices so for HomeKit I split to two devices but then Alexa you can have one account and thus using mesh to bring into one account. May be there is a better solution!
That's the only thing I could think of to suggest. I've never enable UI security.
You can try rolling the firmware back to a prior version using the Diagnostic Tool: Hubitat Diagnostic Tool | Hubitat Documentation
@gopher.ny any other ideas? I am not familiar with Hub Mesh at all.
Thank you for all the feedback. I rolled back the firmware. No change. I was scratching my head then I remembered that I had recently installed ssl certificate for a domain access for external use and removing that fixed the issue.
I am guessing it has to do with devices communicating with each other via local ip and hence invalid certificate.
Now they are in sync but external website access not secure.
I think they paused this feature as it was not working correctly and they had bigger fish to fry during the matter beta. Assuming it might get fixed at some point in the near future now the main issue we're fixed.
Yeah, I'll be taking another look. This would be a neat feature once it's working.
