Fused spur - CLICK SMART
I am currently re-fitting a bathroom that previously had an extractor fan that was controlled by a pull cord. It was powered through a fused spur on the opposite wall,
I will shortly be fitting a new extractor fan, but would like it to be controlled by Hubitat with the help of a Humidity sensor that I already have setup in Hubitat.
I have found the CLICK SMART+ 13A ZIGBEE SMART SWITCHED FUSED SPUR, but really not sure if it will work direct with Hubitat, I can see some users are using the 13A Sockets, but was wondering if anyone is using the Fused Spur ?
This is in the UK.
My bathroom fan was controlled by an on/off switch. I added a Sonoff ZBMINI-L with a Zooz momentary Decora switch. No changes to the wiring were needed.
If you have a multi-speed fan or one with a heater, other options may be available.
