Frigidaire 2.0 app Link
Is anyone working on a Way to link to the Frigidaire 2.0 app To control the thermostat on the room ac?
They have a Alexa and google link.
Curious about this too, Did you figure out any workarounds to control it?
I'm also curious.
Like with any outside system, this mostly depends on whether that system encourages integrations by publishing an API for developers to work with.
If they do, then it’s generally not that difficult for a sufficiently motivated Hubitat dev to write a driver and/or app to integrate with. If they don’t, then the “work” required would likely involve reverse-engineering the API, which is much more time consuming.
As a large appliance manufacturer, I’d be surprised if Frigidaire has an open API for their a/c’s. But anything’s possible.
The workaround is simple. Use a third-party IR controller that integrates with Hubitat. There are several.
