For the past month or two, my C-8 becomes unresponsive every couple of days with a solid blue LED. It seems this started after an update, but I've updated several times since without resolution. Only a power cycle resolves it.
When LED is solid blue:
- Web interface will not open, "This site can't be reached"
- Responds to ping
- Listed in findmyhub
- :8081 opens - 1) Reboot hub doesn't work, 2) Shutdown hub doesn't work 3) Afraid to try Soft reset for fear of losing Z-wave network and don't know if it would help anyway.
- Holding Reset button for 7+ seconds shows no change in LED
Current platform version: 2.4.3.167. Connected via Ethernet cable. Has reserved IP address.
Anything else I should try to resolve this? Is it a sign that my hub is dying? Thanks for your help.
