I have 2 instances on one hub.
Removing itself is not working.
Do i dare to remove the app from the APPSCode page option, and reload?
Thanks.
Two instances of the app in the apps list or two copies of the code in the apps code?
For an app, just click the gear icon next to it in the list, scroll the bottom and press remove.
You also could safely remove all instances and code for HPM and start over, then just run a matchup to pair everything up again if that's what you want to do.
Nope, just one copy in apps code, to in HPM.
Going to remove and reload it as you suggest, that is what i was hoping for.
Thanks!
Oh two listed in the actual HPM listing? Thats an easier fix, just use Unmatch to remove one. If you already deleted the app, you should be fine doing a new matchup as well, it wont hurt anything.
All done, wiped and matched and completed upgrade.
Sweet!
THX
