i have a rule that doesnt work as expected
i expect that the rule will flash the light when the fridge door is open and then stop flashing when the door closes. the below logic works but if i take out the bolded if statement then it doesn't work. it just stays flashing. in the example where it doesnt work i move the delay to before the first if statement. that way if the door is shut by the time it gets to the if statement it just exits.
Select Trigger Events (ANY will trigger)
Kitchen Fridge Door Open(off) turns changed
IF (Kitchen Fridge Door Open(off) is on(F) [FALSE]) THEN
Delay 0:01:30
Flash: Living Room Chair Lamp
END-IF
Exit Rule
ELSE
Off: Living Room Chair Lamp
END-IF
does anyone see any issues in my logic?
