Flash Light
Hey Everyone.
I need some help getting a light to flash. I searched the forum and didn't find what I am trying to do. I also installed a light flasher (third-party app) and it isn't what I'm trying to do.
I want a motion sensor to set a light to flash and then turn the flashing off when I hit switch 2 (off).
The first part is easy with RM. I also can set the light to stop flashing for X mins after the motion stops, but that doesn't help. I need the light to stop until I command it off.
I'm trying to set the motion at the front door for when a package is delivered. Then I will know and turn off the alert.
TIA
Hobs
I would do this in the following way as a Basic Rule or Rule Machine:
Trigger: Motion
Action: Flash light
Wait for event: Button 2 pressed
Action: Turn off light
Hi Sebastien. Thanks for the suggestion. But there is no Action to flash light. I did do what you suggested and got the light to turn on until the off(button 2) is pressed. No joy on flashing though.
Happy 4th of July
Hobs
Try control switches, push buttons > flash switches.
What light switch/dimmer are you using?
What driver are you using?
Ge endbright
Use RM
I tried that. I can turn on the light but there is no way to turn it off. Or am I missing something?
Hobs
Use a conditional within the rule. If switch 2 pressed off then light switch 1 off end if
@PilotHobs Replace with whatever (probably button controller or multi push switch detection would be better but you get the idea)
I don't see where to select the switch 2. It only says if the switch is on or off.
Select trigger (motion sensor)
Select Action (select switch and then flash)
Add Condition if/then
Select switch/button/etc to turn off.
Here is a couple of rules I have tried and they both do the same thing. Start the light flashing and then turn it off.
Screenshot from 2022-07-05 12-42-05
Screenshot from 2022-07-05 11-15-16
this is the log of what it does....
I'm at a loss. Any Ideas?
You probably are going to end up doing this in Rule Machine, and turn the light on for 1 second, off for 1 second, and repeat that until the button is pressed.
Not all devices support the flash (I would rather call it blink) command. In fact, only a couple of my devices do. I don't believe any of the GE/Jasco support that. If there isn't a flash "button" in the top section of the device's settings page, then this command isn't available. I think flash is mostly a Zigbee thing?
Here are a couple screenshots. The first is very typical of all my GE/Jasco devices. Notice no flash command. The second is a Zigbee bulb which does have flash.
I think it's flashing for him but he's having problems controlling it. (turning off the flash with a button) Btw @PilotHobs does your switch you are using support multi tap? (The physical switch must support it to pass that onto hubitat)
The switch is UltraPro. When I connected it Hubitat assigned a generic switch. I changed it to GE Endbrighten and have all the commands (flash/multi-tap).
Before anyone goes crazy and says you can't do that. I have had success with doing it before. I programmed one switch to control another with a double-tap.
I like the idea of setting it to go on/off at one second until the switch is pressed off(button2)
I'm going to try that next.
As long as the double taps are showing in the logs correctly that's fine
