"Firmware update for null failed" repeating error message
I'm getting this error message repeatedly. Anyone know how I can figure out what's causing this?
I checked and I have no device that has a name including null. @mike.maxwell is this coming from zigbee FW update?
Still happening this AM.
I made FW update requests for two Sengled Zigbee devices just to see if they would affect the appearance of this error message. I used two Sengled bulbs, and they resulted in log entries for those types of FW update requests. However, I noticed at that point that one of the devices isn't registering completely, based on the log entry for its FW update:
Logs:
Bulb w/complete registration on Device page, Data section
Bulb w/incomplete registration on Device page, Data section:
2022-10-19 10_31_42-Chrome Main
I've reset and re-joined the second bulb multiple times and it always re-joins in the same way, w/the same missing data. Maybe just a bad bulb for some reason.
Making these Zigbee FW requests doesn't seem to kick off these warning messages immediately after. I do have a lot of them:
Yes these are devices asking for a firmware update that wasnt requested. Im looking at stopping these.
Getting same. Is there a way to determine which device is requesting the update?
Still seeing these warnings in v2.3.3.140
Current hub FW release is 2.3.4.115 so you're quite a bit behind. Consider taking a backup and then installing the current release. I no longer get any warnings of this type, haven't for a while, not sure which update resolved it but the problem is gone for me.
C7 hub is up to date, still getting a lot of these.
Tagging @mike.maxwell ...
Running v2.3.4.153
Am seeing this error 2, Started after i removed a number of unused devices; cant figure it out
