Firmware Update Excruciatingly Slow
I have a Hubitat C-8 running the latest OS version with many ZWave devices...I have been trying to get some of my devices' firmware updated. I did 2 devices just fine. Then after that, any device I try has been extremely slow to upload the FW file. I left one uploading from approx 5PM and by 10 PM it was only 20% done...the next morning I woke up to a message saying it failed around 33%-ish. I dont have the logs from that but what I did was completely shutdown, unplug for a couple of minutes then try again. I also did a database rebuild and ZWave network rebuild.
Here is what I see when I am trying right now:
dev:3702026-09-03 16:58:03.490info
seqNo: 213, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:57:53.549info
seqNo: 212, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:57:43.530info
seqNo: 211, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:57:43.429info
seqNo: 210, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:57:33.398info
seqNo: 209, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:57:23.400info
seqNo: 208, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:57:13.377info
seqNo: 207, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:57:03.355info
seqNo: 206, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:1142026-09-03 16:56:58.017info
seqNo: 205, routeChanged: false, transmissionTime: 2ms, repeaters: [0x12], speed: 100 kbs, rssi: [-95 dBm, -105 dBm, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:2026-09-03 16:56:56.013info
seqNo: 204, routeChanged: true, transmissionTime: 2ms, repeaters: [0x12], speed: 100 kbs, rssi: [-95 dBm, -106 dBm, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:56:51.949info
seqNo: 203, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
seqNo: 202, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:56:42.160info
seqNo: 201, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:862026-09-03 16:56:41.819info
seqNo: 200, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs
dev:862026-09-03 16:56:30.391info
dev:862026-09-03 16:56:29.990info
seqNo: 199, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-96 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:2026-09-03 16:56:29.788info
seqNo: 198, routeChanged: false, transmissionTime: 5ms, repeaters: None, speed: 100 kbs, rssi: [-96 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:56:20.492info
seqNo: 197, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:56:10.558info
seqNo: 196, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:56:00.495info
seqNo: 195, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:55:50.438info
seqNo: 194, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
seqNo: 193, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:55:40.425info
seqNo: 192, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:55:30.347info
seqNo: 191, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:55:20.391info
seqNo: 190, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:55:10.319info
seqNo: 189, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:55:00.265info
seqNo: 188, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
seqNo: 187, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:54:50.094info
seqNo: 186, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:54:40.091info
seqNo: 185, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:54:30.074info
seqNo: 184, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:54:20.056info
seqNo: 183, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-65 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:54:10.020info
seqNo: 182, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-65 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:54:09.919info
seqNo: 181, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:53:59.857info
seqNo: 180, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:53:49.796info
seqNo: 179, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:53:39.813info
seqNo: 178, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:53:29.761info
seqNo: 177, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:53:19.750info
seqNo: 176, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
seqNo: 175, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:53:09.696info
seqNo: 174, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:52:59.703info
seqNo: 173, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:52:49.674info
seqNo: 172, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:52:39.636info
seqNo: 171, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:52:29.637info
seqNo: 170, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:52:29.536info
seqNo: 169, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:52:19.549info
seqNo: 168, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-70 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:52:09.528info
seqNo: 167, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:51:59.513info
seqNo: 166, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:51:49.435info
seqNo: 165, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-68 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:51:39.458info
seqNo: 164, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:51:39.357info
seqNo: 163, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:51:29.326info
seqNo: 162, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-69 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:51:19.350info
seqNo: 161, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:51:09.267info
seqNo: 160, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-67 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:50:59.245info
seqNo: 159, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-71 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:50:49.211info
seqNo: 158, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:50:49.210info
seqNo: 157, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:50:39.166info
seqNo: 156, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-73 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:50:29.087info
seqNo: 155, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:50:19.112info
seqNo: 154, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-71 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:50:09.114info
seqNo: 153, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:59.085info
seqNo: 152, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:58.982info
seqNo: 151, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:49.026info
seqNo: 150, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:2026-09-03 16:49:41.071info
seqNo: 149, routeChanged: true, transmissionTime: 3ms, repeaters: [0x08], speed: 100 kbs, rssi: [-84 dBm, -37 dBm, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:38.894info
seqNo: 148, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-66 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:28.816info
seqNo: 147, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-71 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:18.743info
seqNo: 146, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-71 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:08.640info
seqNo: 145, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:08.289info
seqNo: 144, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-72 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:49:05.206info
seqNo: 143, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-71 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:3702026-09-03 16:48:56.145info
seqNo: 142, routeChanged: false, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-71 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
dev:2026-09-03 16:48:55.313info
seqNo: 141, routeChanged: true, transmissionTime: 1ms, repeaters: None, speed: 100 kbs, rssi: [-71 dBm, N/A, N/A, N/A, N/A], Ack channel: 0, Transmit channel: 0
Following up with more diagnostics. This happens with multiple devices, but the detailed logs below are from a Zooz ZEN37 Kitchen Remote.
Setup:
  • Hubitat C-8, platform 2.5.1.174
  • ZEN37 hardware version 2, firmware 2.30
  • Community Zooz ZEN37 Wall Remote Advanced driver
  • Battery 100%
  • Security: None
  • Direct route to the hub at 100 kbps, no repeaters
  • Z-Wave Details reports PER 0, LWR RSSI 26 dB, and 0 route changes
Already tried, without improvement:
  • Shutting down the hub and disconnecting power for 5 minutes
  • Rebuilding the database
  • Placing the device right next to the hub
  • Disabling the device’s driver for an update attempt
The updater either sits at “Starting transfer of firmware image” or progresses excruciatingly slowly.
During the slow transfer, the device logs show this pattern:
17:24:39.803 FirmwareUpdateMdGet(numberOfReports:5, reportNumber:254)
17:24:49.784 FirmwareUpdateMdGet(numberOfReports:4, reportNumber:255)
17:24:59.809 FirmwareUpdateMdGet(numberOfReports:3, reportNumber:256)
17:25:09.831 FirmwareUpdateMdGet(numberOfReports:2, reportNumber:257)
The requested report number advances by just one approximately every 10 seconds, while the number of requested reports decreases.
Meanwhile, the Z-Wave transmission logs repeatedly show:
routeChanged: false
repeaters: None
speed: 100 kbs
Those transmission logs don’t establish whether every firmware fragment is being delivered, but the consistent 10-second spacing is suspicious.
The community driver labels these messages “Unhandled zwaveEvent.” I understand that label alone doesn’t mean the firmware updater is failing to handle them, and disabling the driver didn’t improve the transfer.
Does this pattern suggest a timeout or retry issue in the firmware transfer? Is there a way to capture the updater’s outgoing firmware reports to determine whether it sends the full requested batch, and whether fragments are being retried?
Happy to provide additional logs. I’d appreciate guidance on what to capture next, since shutdowns, power cycling, and a database rebuild haven’t helped.
Thanks for the link. I appreciate the workaround, but I’m not buying additional hardware just to update my devices’ firmware.
Hubitat supports Z-Wave OTA firmware updates through its built-in updater. My expectation is that the C-8 I already own should handle that without requiring a separate Z-Wave stick, another controller, or a newer hub.
This isn’t limited to a battery device needing to stay awake. I’m seeing it with both a ZEN37 remote and a mains-powered ZEN30 double switch. The ZEN30 only reached around 14–15% after hours, with the logs showing short bursts of activity roughly every 10 seconds, predominantly direct at 100 kbps.
I’m not expecting instant updates, but this makes the feature effectively unusable. A separate controller might work around the problem, but it doesn’t resolve why the built-in updater behaves this way.
Can Hubitat help identify the cause and provide a fix—or explain any specific compatibility limitation affecting these devices?
Should I tag someone like @jtp10181 ?
I am experiencing the exact same issues with the updater. Specifically the 800LR ZEN37 Remote and the 800LR ZSE41 contact sensors. I've tried manual mesh inclusion without security and it still doesn't work while other sensors do.
