PLEASE move this if it's deemed in the wrong place. shrug
I'm using the Gravity: DF2301Q Offline Voice Recognition Sensor. It has it's own speakers (you can add an external) and it's own microphone. This has somewhat fulfilled my needs although it has a limited amount of allowed command words. You can ONLY add 21 (I believe). The rest of the command words are bloat unless you want to use them or repurpose them. The custom wake up word (I used nemo) is somewhat useless as when the device has been idle after sometime I have to use the default wake word (hello robot). I'm running this on a esp32wroom the module is on i2c running on esphome and relaying via mqtt to hubitat. Works pretty efficiently. I had to make the mqtt clear so I can reuse commands. Example: kitchen just throws a number 5. If I trained it to learn kitchen off and kitchen on it would be 5 and 6 which minimizes the amount of usable commands. So I gave in and gave it a list of bulbs and have hubitat rm handle it from there. All in all this is pretty cool. I'm waiting on my esp32box3 to test this on next in hope of more command flexibility/expandability.
This is NOT a shill. I'm genuinely disgusted with alexa.
# ========================================================= # ESP32 + DF2301Q VOICE MODULE # ========================================================= esphome: name: esp32text esp32: board: esp32dev framework: type: esp-idf logger: level: DEBUG api: ota: - platform: esphome # ========================================================= # I2C # ========================================================= i2c: sda: GPIO21 scl: GPIO22 scan: true frequency: 100kHz # ========================================================= # DF2301Q VOICE MODULE # ========================================================= i2c_device: id: voice_module address: 0x64 # ========================================================= # NUMERIC VOICE STATUS # # 1 = Waiting # 2, 3, 4... = Voice command ID # ========================================================= sensor: - platform: template name: "Voice Status" id: voice_status_sensor accuracy_decimals: 0 update_interval: never lambda: |- return 1.0; # ========================================================= # RETURN VOICE STATUS TO 1 AFTER COMMAND # ========================================================= script: - id: voice_waiting mode: restart then: - delay: 500ms - sensor.template.publish: id: voice_status_sensor state: 1 - lambda: |- ESP_LOGD( "VOICE", "VOICE STATUS: 1 (Waiting)" ); # ========================================================= # VOICE COMMAND POLLING # ========================================================= interval: - interval: 250ms then: - lambda: |- uint8_t command_id = 0; auto err = id(voice_module).read_register( 0x02, &command_id, 1 ); if (err == i2c::ERROR_OK && command_id != 0) { ESP_LOGD( "VOICE", "COMMAND ID: %u", command_id ); // Publish the numeric voice command ID. // Example: // Command ID 2 -> Voice Status = 2 id(voice_status_sensor)->publish_state( (float) command_id ); ESP_LOGD( "VOICE", "VOICE STATUS: %u", command_id ); // Clear the DF2301Q command register. uint8_t clear_id = 0; id(voice_module).write_register( 0x02, &clear_id, 1 ); // Return to "Waiting" after 500ms. id(voice_waiting).execute(); }If anyone has a better suggestion for achieving offline voice assist please chime in.
I HAVE NO INTEREST IN HOME ASSISTANT
